Customization with Palworld - Have capability of running mods on my server?
Application Palworld
I am just researching how to enable Admin commands such as giving players items or exp.
  • Research admin command mods
  • Find that they all require UE4SS which is windows only.
  • Investigate pathways to getting admin capabilities with current setup.
I just want the basic admin commands of Give Item / Give Exp. It appears that Kozejin’s Admin Commands (caffeinemodz) partially work on Linux. Specifically, the commands I want, do work.. but not sure how to get UE4SS-Linux integrated into my server installation.
You have to use the Palworld Modded instance type when you first create the instance (it is one of the dropdown selections).
When created, manage the instance and search “workshop” to find the relevant settings for installation and loading.
