Customization with Minecraft - Trying to download Better Mc from Curse forge
Im trying to install neoforge modpack, called Better Mc from curse forge using server files, at first seemed like it worked and said forge was wrong version so i tried to change versions then said server files wasnt correct was out of date, Im just at a loss attempting to do this first time using this type of hosting that didnt let me just choose the modpack, (bisect hosting) Any help would be much appreciated.
  • Ive tried reinstalling neoforge different versions to see if would help
  • Ive deleted the pack and redownloaded server files
  • Ive even tried from a clean slate and doing a step by step froma tutorial i saw online
Make sure you’re not uploading the client manifest zip, and that you’re uploading and unzipping the server pack zip.
You get the server pack zip from the modpack’s page (under Additional Files) and upload that.
If you’ve already done that, you can get the correct Forge version from your launcher, or in the bottom corner of the MC main menu screen.
