Customization with Minecraft - Trying to add a mod and struggling
Product AMP ‘Decadeus’ v2.4.7.0 (Mainline)
I’ve tried a few times each time resetting the pc completely then opening the minecraft server, setting forge up and pressing the update, selecting the version of forge, and then adding the mod zip that I have. After, the server either fails to launch some of the times I tried or does so without mods.
  • reseting everything
  • opening a java minecraft instance and letting it update and launch
  • closing it and setting it to forge as well as selecting the forge version and pressing update
  • dragging and dropping the mod or using sftp
Make sure to read the console or latest.log, as that’s where you’ll find the error.
