Field | Value |
Operating System | Linux - Ubuntu 24.04.2 on x86_64 |
Product | AMP ‘Phobos’ v2.6.2.0 (Mainline) |
Virtualization | None |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | No |
Current State | Ready |
I installed the skin restorer plugin and when that didnt work i also installed luckperms and vault, and still nothing worked, i believe the firewall is blocking the plugins ability to work here is a link to the ports and domains, Firewall - SR
- I install skin restorer plugin
- I try to use the plug in and no commands work
- Installed luckperms and vault to see if it was needed and still no commands work for all 3 plugins
