Customization with Minecraft - server wont start after adding mods
Virtualization QEMU_KVM
as the title says the server will not start and i do not know why it says its due to something i have done but i do not know what do you have any idea?
  • make the mods folder
  • change to forge and select the correct version
  • transfer mods into the mods folder
  • hit start
here is what the log says.
[31Oct2023 01:09:52.914] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher running: args [–gameDir, ., --launchTarget, fmlserver, --fml.forgeVersion, 36.2.39, --fml.mcpVersion, 20210115.111550, --fml.mcVersion, 1.16.5, --fml.forgeGroup, net.minecraftforge, nogui]
[31Oct2023 01:09:52.917] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher 8.1.3+8.1.3+main-8.1.x.c94d18ec starting: java version 17.0.4 by Debian
If that isn’t the full log, please provide the full logs/latest.log using a service like: https://mclo.gs/
And be sure to use SFTP or AMP’s file manager to upload mods, as transferring files using the OS’s file manager can break file perms.
that is the full log unfortunately.
and i used sftp to upload the mods into the folder
Oh weird. Try stopping/starting the AMP instance to see if that kicks things over.
Otherwise try starting it without the mods to see if they might be the issue.
Then if all else fails, right click the instance and hit View Logs, then send those over, might have some more info.
how would i send the log over? sorry for the silly question
Should be able to use any pastebin-like service, or just https://mclo.gs/, and shoot over the new URL it gives you after you upload things
Vanilla Server Log [#wIeTDMU] - mclo.gs this should be it
Maybe try deleting the libraries folder, then hit Download/Update in AMP
Wait. You need to be using Java 8 or 11 for Forge 1.16.5
is it the JDK11 i need turns out i didnt fix it it just took longer to crash
