Customization with Minecraft - Server with modpack doesn't work
Product AMP ‘Phobos’ v2.6.0.2 (Mainline)
How come my modpack keeps running 300+ ticks behind? All the players move normally except all other living beings. It stutters and I dont understand whats causing it, the server doesnt look overloaded but everytime the console says it is!
  • Using less mods
  • Tried to reset the instance
  • Tried to reset server world
As long as the TPS is around 18-19 you don’t need to worry about those messages.
If it drops below that, you can use the Spark server-side mod to diagnose what’s overusing the CPU. Usually loading or generating too many chunks, the default render distance of 10 sometimes needs to be set to 8. It could also be that there are too many entities, and you may have to adjust some of the farms you have set up.
