Customization with Minecraft - Request to open UDP port for voice chat mod
Hello,
I’m trying to use the Simple Voice Chat mod on my Minecraft server. It requires an open UDP port (default is 24454) in order to function.
Currently, voice chat does not work — most likely because the necessary UDP port isn’t open.
Could you please either:
Open UDP port 24454, or
Assign me a different open UDP port that I can configure manually in the server settings?
Thank you!
  • Installed Simple Voice Chat mod on Minecraft server
  • Uploaded it to the correct folder and restarted the server
  • Tried using voice chat but it doesn’t work — likely due to UDP port not open
This is not Hostinger support
Click on the “pencil” icon n your instance, add the port yourself
