Customization with Minecraft - Quest system does not work in server, it works local
When I install Craftoria on Hostinger, the quest book does not work for anyone. If install local and play the quest book works. Hostinger does not have the mod I use or I can’t find it so I install the neoforge version that my modpack uses and copy and paste the mod files to the file manager. I must be doing something wrong because the quest book will not work this way. Is there a better way to install Craftoria on this server?
  • Installed the Neoforge version the modpack uses
  • Deleted Mods Folder
  • Copied and pasted mods folder from local server
This isn’t Hostinger support, just the forum for AMP, but we can give you pointers and suggestions on how to resolve things.
Make sure that the server jar is set to Autoselect and check the log to see if the mod(s) are loading correctly. You should also double check that you have the mod jar files in the mods directory
