| Product | AMP ‘Callisto’ v2.5.1.8 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
The problem is that I want to install a modpack that requires Forge to work, but when I try to start the server, an error occurs. I have already tried uploading the modpack in question to the file manager before attempting to start the server, but it didn’t work, showing the same error during the process.
Error in Console:
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:109)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:70)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:34)
Caused by: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader ‘bootstrap’)
at net.minecraft.launchwrapper.Launch.(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
… 3 more
- Create a new instance of minecraft
- change in configuration the: Server type to Forge
- Change to any version of minecraft forge (expample 1.12.2)
- Select the JAR for the version of forge
- Return to status and try to start the server
