Customization with Minecraft - plugins activation?
Hey, trying to install a couple plugins for my server. I installed them initially with the game running. However, after stopping the server, I started it back up assuming that it needed to restart to enable the plugins but they still don’t work. Do I need to stop the INSTANCE?
  • Installed 2 plugins, with server running
  • Stopped server, then started server
  • No other steps has occured
Make sure you’re using a server type that supports plugins such as Paper.
If the plugins still don’t load, check the console or logs/latest.log to see why.
Yeah that’s probably it. Server type is just vanilla. Side question, when you enable whitelist for my server, where do I go to add players to said whitelist?
You run the commands in the console:
