| Product | AMP ‘Callisto’ v2.5.0.14 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
I updated to MC 1.21 (Paper), but I do not see any Plugins loaded. Even if they’re not supported (for argument’s sake), they usually show up in red if they were unable to run.
It’s almost as if they’re not even being detected.
Sorry, forgot to paste in the console logs.
Console12:55:35
java.lang.RuntimeException: Failed to open plugin jar plugins/8631-v541095__CoreProtect.jar
at io.papermc.paper.pluginremap.PluginRemapper.remap(PluginRemapper.java:339) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.pluginremap.PluginRemapper.remapPlugin(PluginRemapper.java:266) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.pluginremap.PluginRemapper.rewritePluginDirectory(PluginRemapper.java:204) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.plugin.provider.source.DirectoryProviderSource.prepareContext(DirectoryProviderSource.java:42) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.plugin.provider.source.DirectoryProviderSource.prepareContext(DirectoryProviderSource.java:17) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.plugin.util.EntrypointUtil.registerProvidersFromSource(EntrypointUtil.java:14) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paper.plugin.PluginInitializerManager.load(PluginInitializerManager.java:109) ~[paper-1.21.jar:1.21-15-2df432f]
at net.minecraft.server.Main.main(Main.java:122) ~[paper-1.21.jar:1.21-15-2df432f]
at org.bukkit.craftbukkit.Main.main(Main.java:298) ~[paper-1.21.jar:1.21-15-2df432f]
at io.papermc.paperclip.Paperclip.lambda$main$0(Paperclip.java:42) ~[app:?]
at java.base/java.lang.Thread.run(Thread.java:1583) ~[?:?]
Caused by: java.util.zip.ZipException: zip END header not found
at jdk.zipfs@21.0.2/jdk.nio.zipfs.ZipFileSystem.findEND(ZipFileSystem.java:1320) ~[jdk.zipfs:?]
at jdk.zipfs@21.0.2/jdk.nio.zipfs.ZipFileSystem.initCEN(ZipFileSystem.java:1541) ~[jdk.zipfs:?]
at jdk.zipfs@21.0.2/jdk.nio.zipfs.ZipFileSystem.<init>(ZipFileSystem.java:179) ~[jdk.zipfs:?]
at jdk.zipfs@21.0.2/jdk.nio.zipfs.ZipFileSystemProvider.getZipFileSystem(ZipFileSystemProvider.java:125) ~[jdk.zipfs:?]
at jdk.zipfs@21.0.2/jdk.nio.zipfs.ZipFileSystemProvider.newFileSystem(ZipFileSystemProvider.java:120) ~[jdk.zipfs:?]
at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:528) ~[?:?]
at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:440) ~[?:?]
at io.papermc.paper.pluginremap.PluginRemapper.remap(PluginRemapper.java:290) ~[paper-1.21.jar:1.21-15-2df432f]
... 10 more
- Install plugin
- Launch Server
- Check for running plugins
- 0 plugins found
