Tony
1
Field |
Value |
Operating System |
Product |
AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization |
Docker |
Application |
Minecraft |
Module |
MinecraftModule |
Running in Container |
Yes |
Current State |
Ready |
Tried repeatedly connecting to server moving files and folders and still the server is saying its missing all of the mods in the modpack
- Trying to connect to server
- Failing to connect with mods installed
- Hostinger is not installing any of the mods even with hostinger guides
Make sure that you’ve selected the correct modloader and version that the mods need, otherwise the mods will not load
Tony
3
i think the version is wrong but how do i change it to 1.20.1?
In the instance’s settings (search bar in the upper right)
Tony
5
ive set it to forge 1.20.1 which i need but in file manager its 1.21.3 and its not updating or changing even after refreshing and updating
You need to leave the Jar as Autoselect
for that version, and press Download/Update
to make sure Forge is installed.
Tony
7
it is on autoselect and ive pressed download/update but its failing to start the server
What does it say in the logs?
Tony
9
Forge: net.minecraftforge:47.3.0[19:40:54] [main/ERROR] [minecraft/Main]: Failed to start the minecraft server
net.minecraftforge.fml.LoadingFailedException: Loading errors encountered: [
Oculus (oculus) has failed to load correctly
?7java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
Remove Oculus, it can’t run server-side
Tony
11
Right that works thanks alot
system
Closed
12
