| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
I want to use a modpack from CurseForge. I install the Server Pack version of the modpack and upload it to a mods folder under File Manager, and I make sure that the Server is set to Forge with the corrrct version. I open the modpack and try to connect to the server but I keep getting a “channel of mod failed to connect” error. Happens with multiple modpacks.
- Using CurseForge, install the Server Pack for the modpack
- Upload the Server Modpack Via WinSCP
- Update server to be on Forge/Neoforge, and correct version.
- Have the same version of the Modpack installed, connect to server “channel of mod failed to connect” error
