Field
Value
Operating System
Product
AMP ‘Callisto’ v2.5.0.6 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Ready
I downloaded the mods and transferred them to file manager and opened each file. However, everytime I try to start the game it tells me the server does not have any of the mods. Not sure what im doing wrong.
created server
added mods to computer
transferred mods from computer to file manager
opened every mod in file manager
You need to be using the same mod loader and mod loader version as what you client is using. (under Server Settings
They are the same version. Its weird because it says only some of them are not in the server, but they’re all in the file manager.
Have you restarted the server since uploading the mods? And are the mods in the mods
folder?
Yes, I actually figured it out. There were multiple mods folders in the server file manager for some reason and I finally found that right one!
Might’ve unzipped something weird maybe?
The right one would just be the mods
folder in the main directory.
system
Closed
27 May 2024 06:02
7
