Customization with Minecraft - Mod Pack Issues
I have been having issues with running a fabric mod pack on my server. As soon as I joined the server, the world was glitched out and when I tried to open up the inventory, the server crashed. I got the following error 255 “java.lang.IllegalStateException: Config property is not linked yet”
  • Added the mod pack to the server
  • Started the server
  • Joined the server
  • opened the inventory
Full Crash Report
---- Minecraft Crash Report ----
// Shall we play a game?
Time: 2024-03-20 20:59:52
Description: Unexpected error
	at com.mrcrayfish.framework.api.config.AbstractProperty.get(AbstractProperty.java:89)
	at com.mrcrayfish.backpacked.util.ClientUtils.createBackpackTooltip(ClientUtils.java:23)
	at com.mrcrayfish.backpacked.item.BackpackItem.method_7851(BackpackItem.java:62)
	at net.minecraft.class_1799.method_7950(class_1799.java:647)
	at net.minecraft.class_310.method_1485(class_310.java:839)
	at net.minecraft.class_7454.method_43796(class_7454.java:20)
	at net.minecraft.class_1126.method_4799(class_1126.java:26)
	at net.minecraft.class_1124$class_7457.method_43807(class_1124.java:61)
	at net.minecraft.class_1124.method_43804(class_1124.java:42)
	at net.minecraft.class_310.method_43759(class_310.java:2653)
	at net.minecraft.class_310.method_46740(class_310.java:857)
	at net.minecraft.class_1761.method_47314(class_1761.java:128)
	at net.minecraft.class_1761.method_47306(class_1761.java:107)
	at net.minecraft.class_7706.method_47331(class_7706.java:2054)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183)
	at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179)
	at java.base/java.util.Iterator.forEachRemaining(Iterator.java:133)
	at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1845)
	at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499)
	at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
	at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
	at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596)
	at net.minecraft.class_7706.method_47337(class_7706.java:2054)
	at net.minecraft.class_7706.method_47330(class_7706.java:2063)
	at net.minecraft.class_481.<init>(class_481.java:181)
	at net.minecraft.class_490.method_25426(class_490.java:53)
	at net.minecraft.class_437.method_25423(class_437.java:297)
	at net.minecraft.class_310.method_1507(class_310.java:1080)
	at net.minecraft.class_310.method_1508(class_310.java:2009)
	at net.minecraft.class_310.method_1574(class_310.java:1883)
	at net.minecraft.class_310.method_1523(class_310.java:1181)
	at net.minecraft.class_310.method_1514(class_310.java:802)
	at net.minecraft.client.main.Main.main(Main.java:250)
	at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:470)
	at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74)
	at net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Render thread
Stacktrace:
-- Affected level --
Details:
	All players: 1 total; [class_746['RoseVoid125'/420, l='ClientLevel', x=-4.50, y=86.00, z=-5.50]]
	Chunk stats: 729, 443
	Level dimension: minecraft:overworld
	Level spawn location: World: (0,87,0), Section: (at 0,7,0 in 0,5,0; chunk contains blocks 0,-64,0 to 15,319,15), Region: (0,0; contains chunks 0,0 to 31,31, blocks 0,-64,0 to 511,319,511)
	Level time: 3981 game time, 3981 day time
	Server brand: fabric
	Server type: Non-integrated multiplayer server
Stacktrace:
	at net.minecraft.class_638.method_8538(class_638.java:458)
	at net.minecraft.class_310.method_1587(class_310.java:2406)
	at net.minecraft.class_310.method_1514(class_310.java:826)
-- Last reload --
Details:
	Reload number: 1
	Reload reason: initial
	Finished: Yes
	Packs: vanilla, file/nofog-no-optifine, fabric, Moonlight Mods Dynamic Assets
-- System Details --
Details:
	Minecraft Version: 1.20.1
	Minecraft Version ID: 1.20.1
	Operating System: Mac OS X (x86_64) version 14.2.1
	Java Version: 17.0.8, Microsoft
	Java VM Version: OpenJDK 64-Bit Server VM (mixed mode), Microsoft
	Memory: 449071056 bytes (428 MiB) / 2147483648 bytes (2048 MiB) up to 2147483648 bytes (2048 MiB)
	CPUs: 12
	Processor Vendor: GenuineIntel
	Processor Name: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
	Identifier: Intel64 Family 6 Model 158 Stepping 10
	Microarchitecture: Coffee Lake
	Frequency (GHz): 2.60
	Number of physical packages: 1
	Number of physical CPUs: 6
	Number of logical CPUs: 12
	Graphics card #0 name: Intel UHD Graphics 630
	Graphics card #0 vendor: Intel
	Graphics card #0 VRAM (MB): 1536.00
	Graphics card #0 deviceId: 0x3e9b
	Graphics card #0 versionInfo: Revision ID: 0x0000, gMux Version: 5.0.0
	Graphics card #1 name: AMD Radeon Pro 5300M
	Graphics card #1 vendor: AMD (0x1002)
	Graphics card #1 VRAM (MB): 4096.00
	Graphics card #1 deviceId: 0x7340
	Graphics card #1 versionInfo: Revision ID: 0x0043, ROM Revision: 113-D3220E-190, VBIOS Version: 113-D32207P1-020, Option ROM Version: 113-D32207P1-020, EFI Driver Version: 01.A1.190, gMux Version: 5.0.0
	Memory slot #0 capacity (MB): 8192.00
	Memory slot #0 clockSpeed (GHz): 2.67
	Memory slot #0 type: DDR4
	Memory slot #1 capacity (MB): 8192.00
	Memory slot #1 clockSpeed (GHz): 2.67
	Memory slot #1 type: DDR4
	Virtual memory max (MB): 18432.00
	Virtual memory used (MB): 11843.99
	Swap memory total (MB): 2048.00
	Swap memory used (MB): 1608.75
	JVM Flags: 8 total; -Xss1M -Xmx2G -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M
	Fabric Mods:
		amendments: Amendments 1.20-1.1.10
		architectury: Architectury 9.2.14
		backpacked: Backpacked 2.2.7
		bakery: Bakery 1.1.3
		balm-fabric: Balm 7.2.2
		beachparty: Beachparty 1.1.3
		beautify: Beautify 1.1.0+1.20
		bloomingnature: Blooming Nature 1.0.5
		brewery: Brewery 1.1.4
		candlelight: Candlelight 1.2.8
		chimes: Chimes 2.0.1
		cloth-config: Cloth Config v11 11.1.118
			cloth-basic-math: cloth-basic-math 0.6.1
		clumps: Clumps 12.0.0.3
		creeperoverhaul: Creeper Overhaul 3.0.2
		decorative_blocks: Decorative Blocks 4.1.3
		digs_dnd_origins: Digs DnD Origins 1.20.1-0.0.11
		doapi: Lets Do Api 1.2.8
			blue_endless_jankson: jankson 1.2.1
			terraform-wood-api-v1: Terraform Wood API (v1) 7.0.1
		dramaticdoors: Dramatic Doors (QuiFabrge) 1.20.1-3.1.5
		endermanoverhaul: Enderman Overhaul 1.0.4
		fabric-api: Fabric API 0.92.0+1.20.1
			fabric-api-base: Fabric API Base 0.4.31+1802ada577
			fabric-api-lookup-api-v1: Fabric API Lookup API (v1) 1.6.36+1802ada577
			fabric-biome-api-v1: Fabric Biome API (v1) 13.0.13+1802ada577
			fabric-block-api-v1: Fabric Block API (v1) 1.0.11+1802ada577
			fabric-block-view-api-v2: Fabric BlockView API (v2) 1.0.1+1802ada577
			fabric-blockrenderlayer-v1: Fabric BlockRenderLayer Registration (v1) 1.1.41+1802ada577
			fabric-client-tags-api-v1: Fabric Client Tags 1.1.2+1802ada577
			fabric-command-api-v1: Fabric Command API (v1) 1.2.34+f71b366f77
			fabric-command-api-v2: Fabric Command API (v2) 2.2.13+1802ada577
			fabric-commands-v0: Fabric Commands (v0) 0.2.51+df3654b377
			fabric-containers-v0: Fabric Containers (v0) 0.1.64+df3654b377
			fabric-content-registries-v0: Fabric Content Registries (v0) 4.0.11+1802ada577
			fabric-convention-tags-v1: Fabric Convention Tags 1.5.5+1802ada577
			fabric-crash-report-info-v1: Fabric Crash Report Info (v1) 0.2.19+1802ada577
			fabric-data-attachment-api-v1: Fabric Data Attachment API (v1) 1.0.0+de0fd6d177
			fabric-data-generation-api-v1: Fabric Data Generation API (v1) 12.3.4+1802ada577
			fabric-dimensions-v1: Fabric Dimensions API (v1) 2.1.54+1802ada577
			fabric-entity-events-v1: Fabric Entity Events (v1) 1.6.0+1c78457f77
			fabric-events-interaction-v0: Fabric Events Interaction (v0) 0.6.2+1802ada577
			fabric-events-lifecycle-v0: Fabric Events Lifecycle (v0) 0.2.63+df3654b377
			fabric-game-rule-api-v1: Fabric Game Rule API (v1) 1.0.40+1802ada577
			fabric-item-api-v1: Fabric Item API (v1) 2.1.28+1802ada577
			fabric-item-group-api-v1: Fabric Item Group API (v1) 4.0.12+1802ada577
			fabric-key-binding-api-v1: Fabric Key Binding API (v1) 1.0.37+1802ada577
			fabric-keybindings-v0: Fabric Key Bindings (v0) 0.2.35+df3654b377
			fabric-lifecycle-events-v1: Fabric Lifecycle Events (v1) 2.2.22+1802ada577
			fabric-loot-api-v2: Fabric Loot API (v2) 1.2.1+1802ada577
			fabric-loot-tables-v1: Fabric Loot Tables (v1) 1.1.45+9e7660c677
			fabric-message-api-v1: Fabric Message API (v1) 5.1.9+1802ada577
			fabric-mining-level-api-v1: Fabric Mining Level API (v1) 2.1.50+1802ada577
			fabric-model-loading-api-v1: Fabric Model Loading API (v1) 1.0.3+1802ada577
			fabric-models-v0: Fabric Models (v0) 0.4.2+9386d8a777
			fabric-networking-api-v1: Fabric Networking API (v1) 1.3.11+1802ada577
			fabric-networking-v0: Fabric Networking (v0) 0.3.51+df3654b377
			fabric-object-builder-api-v1: Fabric Object Builder API (v1) 11.1.3+1802ada577
			fabric-particles-v1: Fabric Particles (v1) 1.1.2+1802ada577
			fabric-recipe-api-v1: Fabric Recipe API (v1) 1.0.21+1802ada577
			fabric-registry-sync-v0: Fabric Registry Sync (v0) 2.3.3+1802ada577
			fabric-renderer-api-v1: Fabric Renderer API (v1) 3.2.1+1802ada577
			fabric-renderer-indigo: Fabric Renderer - Indigo 1.5.1+1802ada577
			fabric-renderer-registries-v1: Fabric Renderer Registries (v1) 3.2.46+df3654b377
			fabric-rendering-data-attachment-v1: Fabric Rendering Data Attachment (v1) 0.3.37+92a0d36777
			fabric-rendering-fluids-v1: Fabric Rendering Fluids (v1) 3.0.28+1802ada577
			fabric-rendering-v0: Fabric Rendering (v0) 1.1.49+df3654b377
			fabric-rendering-v1: Fabric Rendering (v1) 3.0.8+1802ada577
			fabric-resource-conditions-api-v1: Fabric Resource Conditions API (v1) 2.3.8+1802ada577
			fabric-resource-loader-v0: Fabric Resource Loader (v0) 0.11.10+1802ada577
			fabric-screen-api-v1: Fabric Screen API (v1) 2.0.8+1802ada577
			fabric-screen-handler-api-v1: Fabric Screen Handler API (v1) 1.3.30+1802ada577
			fabric-sound-api-v1: Fabric Sound API (v1) 1.0.13+1802ada577
			fabric-transfer-api-v1: Fabric Transfer API (v1) 3.3.4+1802ada577
			fabric-transitive-access-wideners-v1: Fabric Transitive Access Wideners (v1) 4.3.1+1802ada577
		fabricloader: Fabric Loader 0.15.7
			mixinextras: MixinExtras 0.3.5
		fallingtree: FallingTree 4.3.4
		farmersdelight: Farmer's Delight 1.20.1-1.4.3
		framework: Framework 0.6.16
			com_electronwill_night-config_core: core 3.6.6
			com_electronwill_night-config_toml: toml 3.6.6
			org_javassist_javassist: javassist 3.29.2-GA
			org_reflections_reflections: reflections 0.10.2
		geckolib: GeckoLib 4 4.4.2
			com_eliotlash_mclib_mclib: mclib 20
		handcrafted: Handcrafted 3.0.6
		herbalbrews: Herbal Brews 1.0.5
		icarus: Icarus 1.16
		java: OpenJDK 64-Bit Server VM 17
		lambdynlights: LambDynamicLights 2.3.2+1.20.1
			pride: Pride Lib 1.2.0+1.19.4
			spruceui: SpruceUI 5.0.0+1.20
		lithium: Lithium 0.11.2
		majruszlibrary: Majrusz Library 7.0.5
		majruszsenchantments: Majrusz's Enchantments 1.10.7
		meadow: Meadow 1.3.5-1
		midnightlib: MidnightLib 1.4.1
		minecraft: Minecraft 1.20.1
		moonlight: Moonlight 1.20-2.11.4
		mousetweaks: Mouse Tweaks 2.25
		naturescompass: Nature's Compass 1.20.1-2.2.3-fabric
		notenoughanimations: NotEnoughAnimations 1.7.1
		origins: Origins 1.10.0
			apoli: Apoli 2.9.0
				additionalentityattributes: Additional Entity Attributes 1.3.0+1.20.0
				calio: Calio 1.11.0
				cardinal-components-base: Cardinal Components API (base) 5.2.1
				cardinal-components-entity: Cardinal Components API (entities) 5.2.1
				playerabilitylib: Pal 1.8.0
			reach-entity-attributes: Reach Entity Attributes 2.4.0
		pehkui: Pehkui 3.7.12+1.14.4-1.20.4
			kanos_config: Kanos Config 0.4.1+1.14.4-1.19.4
		resourcefulconfig: Resourcefulconfig 2.1.2
		resourcefullib: Resourceful Lib 2.1.23
			com_teamresourceful_bytecodecs: bytecodecs 1.0.2
			com_teamresourceful_yabn: yabn 1.0.3
		sound_physics_remastered: Sound Physics Remastered 1.20.1-1.3.1
		supplementaries: Supplementaries 1.20-2.8.6
			mixinsquared: MixinSquared 0.1.1
		trinkets: Trinkets 3.7.2
		vinery: Vinery 1.4.11
		voicechat: Simple Voice Chat 1.20.1-2.4.32
		watching: From The Fog 1.9.2
		waystones: Waystones 14.1.3
		xaerominimap: Xaero's Minimap 23.9.7
		xaeroworldmap: Xaero's World Map 1.37.8
	Launched Version: fabric-loader-0.15.7-1.20.1
	Backend library: LWJGL version 3.3.1 SNAPSHOT
	Backend API: AMD Radeon Pro 5300M OpenGL Engine GL version 4.1 ATI-5.2.4, ATI Technologies Inc.
	Window size: 3072x1920
	GL Caps: Using framebuffer using OpenGL 3.2
	GL debug messages: <disabled>
	Using VBOs: Yes
	Is Modded: Definitely; Client brand changed to 'fabric'
	Type: Client (map_client.txt)
	Graphics mode: fast
	Resource Packs: vanilla, file/nofog-no-optifine (incompatible), fabric, Moonlight Mods Dynamic Assets
	Current Language: en_us
	CPU: 12x Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
I’d suggest double checking that the mod isn’t missing any dependencies and that you’re running it on the right MC/Fabric version, not really an AMP issue. If you’re with Hostinger you’ll want to contact their support instead.
