Customization with Minecraft - Mod having trouble connecting
Product AMP ‘Callisto’ v2.5.1.2 (Mainline)
I am having trouble with the mod “GlitchCore”. I have added it to both the server’s file manager mod folder as well as Minecraft’s game file mod folder. When I go to load the game though it says that it lost connection because "Channel of mod “GlitchCore” failed to connect: This channel is missing on the server side, but required on the client. I am not sure what is causing this as I have made sure many times that the mod is in the server folder and that they are the same version of the mod.
  • Manually added mods to the server fild manager.
  • Added those same mods to the minecraft game folder.
  • Loaded up the game and then tried to connect to the server using the IP.
  • Game says it lost connection saying “Channel of mod “GlitchCore” failed to connect: This channel is missing on the server side, but required on the client!”
Be sure that you’ve selected the right modloader and version in the server’s settings, otherwise the mods won’t load
