Customization with Minecraft - Minecraft Server allow-flight=true configuration not holding
Virtualization QEMU_KVM
When I try to modify my server.properties file setting of ‘allow-flight=false’ to ‘allow-flight=true’, while the server is off, and I save it, and start the server back up, for some reason, something forces the config setting back to ‘allow-flight=false’.
Am I doing something wrong? It seems like this happens for some arbitrary settings, they dont hold after editting and restarting the server.
  • Stopped the server
  • editted the server.properties config file from ‘allow-flight=false’ to ‘allow-flight=true’ and saved it
  • Restarted the server and the server.properties config file flipped back to ‘allow-flight=false’
Either:
A) Modify the setting in AMP itself, not by editing server.properties (you can use the search box in the top right to jump to it)
B) Right click server.properties in the file manager after editing it and import it to persist your changes.
How do I access the AMP settings? I go to AMP Core and theres very little that relates to this subject. What am I looking for?
Should be under ConfigurationGameplay and Difficulty after managing the MC instance, otherwise you can use the search bar in the upper right
