| Product | AMP ‘Decadeus’ v2.4.7.0 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
impossible to use java 17 to launch the server under fabric
- downloading and instaling java 17 and eclipse temurin 17
- selection of temurin17jdk in configuration java and memorie
- Caused by: java.lang.IllegalArgumentException: The requested compatibility level JAVA_17 could not be set. Level is not supported by the active JRE or ASM version (Java 18.0, ASM 9.0 (ASM10_EXPERIMENTAL))
