Just so you’re aware, we are not Hostinger support, so you may run into issues that only they can help you with.
Anyways, make sure to set the server type and server version to what the pack needs, then hit download/update (look in your launcher for version info)
You may run into issues with client side mods being on the server, as this modpack does not have a proper server pack to download.
If you run into issues there, you’ll need to read the log to figure out which mods may be incompatible.
