Customization with Minecraft - importing the configuration doesn't work
Virtualization QEMU_KVM
hello, i have a problem saving the server properties, i import the configuration but it doesn’t seem to work when i start the server, it’s like if it didn’t save in the first place, what do i do?
  • restarted the server
  • updated the server
  • save and import the configuration
The amp control panel overwrite the server.properties file so if you need to change anything, you would go to your Minecraft instance and then configuration then server settings.
is there a way i can disable that? the rewriting? because the server settings doesn’t have the option to disable onlinemode, the only way is through server.properties
What’s the purpose for disabling online?
If you’re using a Proxy then there’s a setting to control that - but if you’re wanting to allow people who haven’t paid for the game to join then we won’t assist you with how to do that.
