I am trying to get BlueMap to work with my Minecraft java server using Amp.
Not working. I have tried 3 TCP ports. One inside the “AMP Service Port Ranges” and one insider the “Application Port Ranges” and one outside both. None work. I can see the instance has the port with a green check mark indicating it is listening. In my case, the problem was my Network Security Group in Azure. I had to add a NAT for allowing the port to the AMP vm server. I can share that the port inside the “Application Port Ranges” is the winner. That is found from the main Amp screen, CONFIGURATION > INSTANCE DEPLOYMENT. Good luck!
