Customization with Minecraft - i dont see where is the Bukkit.yml
i need this fills for up the amount of entity spawn in my serveur pls
  • i have going to file and looked in world, config etc but dont found it
  • nothing more cause idk where to find it
  • idk where other side to looking
Hi, I am a user on this forums!
I am not aware of your situation. But, I believe you have to install a bukkit server then launch it for the Bukkit.yml to generate. Or it may be nested in a config folder or in a plugins folder.
im on a hostinger serveur with neoforge if that can help u to help me
This indeed helpful. A neoforge server ddoesn’t have a bukkit.yml file. You can edit the main server.properties or find the config file for each mod individually in the config folder of your server. Each mod has its own file to edit the mod’s own settings.
