Customization with Minecraft - GeyserMc - MCXboxBroadcast
Virtualization QEMU_KVM
Im trying to use an extension for the GeyserMC plugin on my minecarft server. The only problem is that in order to fully set up this extension i need the server to give me an authentication code but one never shows up. THis is the link to the github README.md GitHub - MCXboxBroadcast/Broadcaster: A simple Geyser extension that broadcasts the server over Xbox Live.
  • dowloaded the plugin GeyserMc
  • downloaded the GeyserMC extension “MCXboxBroadcast”
  • restarted the server and viewed the console
Did you put the extension in the plugins/Geyser/extensions/ folder?
yes, the console even says that it is enabling the extension when the server starts.
Coolio, was just sanity-checkin that
Mind shooting over your logs/latest.log with https://mclo.gs/ ?
Also might be worth clearing out any configs that the extension has generated, just in case something was getting hung up there.
I also just tried deleting the plugin’s config file, but it started up the same as usual.
(edit)
Well when i check the log it actually gave me an auth code, but does not through the console.
Weird, but that fixed my problem. Thanks!
Oh! I didn’t even think of that, it must’ve been read weirdly by AMP. I’ll have to remember that
