Field | Value |
Product | AMP ‘Callisto’ v2.5.1.8 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Stopped |
I tried to extract the file but an error message popped out saying:" error Status 3" or “State 3”
- Step 1 - Prepare Your World File First, locate your world file according to your operating system: Windows 10 Press the Windows Key (Start) Type in %appdata% and press enter Open the .minecraft folder and then go to the saves folder Find your save and drag the folder to your desktop
- Once you have located your world folder and copied it to an accessible location, rename it to a name that will help you easily locate it, using only lowercase letters. Then, archive or compress it into a .zip file so it can be uploaded in the next step.
- Log in to your Game Panel and stop the instance. Next, click on Manage:
- Choose File Manager:
- Next, delete the current world folder by using right-click and then Trash:
- Drag your world’s .zip file from your desktop to the File Manager window:
- Once your world .zip file is uploaded, you’ll need to extract it by using right-click and then Extract:
