Field | Value |
Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Failed |
I am trying to run a Mohist 1.20.1 custom server on Hostinger. I uploaded the mohist.jar file and set a startup command with optimized Java arguments. However, when I start the server, it stops within 5 seconds without a clear error message. The panel suggests checking the log files, but there is no obvious issue in latest.log.
I would like assistance in troubleshooting why the server is failing to start. Could you check if the startup command is correctly applied, or if there is any restriction on custom .jar files in Hostinger’s environment?
- Uploaded a custom mohist.jar file to the server.
- Set up a custom startup command with Java arguments: java -Xmx12G -jar mohist.jar nogui
- Started the server from the Hostinger panel.
- The server stops within 5 seconds with the error: “The Minecraft server stopped within 5 seconds of starting…”
