| Product | AMP ‘Callisto’ v2.5.0.14 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
Watched this video and the procedure he uses to install plugins does not work.
For instance we want to install geyser on the java server we created. Are we supposed to stop the server first? If we do that then configuration/minecraft menu option disappears which means we cant get to the place where we select paper for the plugin. Also, once you select paper and click update/download then install the plugin do you then set the configuration back to official and then restart? So confused. Please help.
- stopped server
- change configuration to paper
- install plugin
