Customization with Minecraft - configuring Simple Voice Chat mod for forge
simple voice chat mod requires extra set up on server side to work and I cannot find a guide to use to set it up, I tried a few other sites tutorials but was unable to view/access needed files
  • created mods folder
  • put mod in folder
  • cannot find guide for hostinger as different hosts seem to handle this differently
(Just a general note, we are not Hostinger, this is just the AMP forum)
You need to add the SimpleVC UDP port to the instance (check it’s config for what port specifically). Stop the instance, edit ports, add the port, then start the instance again.
