Customization with Minecraft - changing file "server.properties" and plugins
Product AMP ‘Callisto’ v2.5.0.14 (Mainline)
i have two main issues
  1. every time i try to change a line in “server.properties” it switches back to what it was once i turn on the server
  2. after istalling the plugins im not sure why they aren’t working
    thank you in advance
  • edited the file “server.properties”
  • saved the edited file
  • turned on the server and seeing that the file went back to what it was
You don’t edit config files manually with AMP, you the settings via the web interface.
Also are you using a server type that supports plugins?
