Customization with Minecraft - Changing config file
I changed /config/globalgamerules.cfg spawnradius from 6000 to 10. When I restart the server the state of globalgamerules.cfg file comes to the one before my changes. It appear that I can’t really change the file.
  • I tried changing the file and restart the server
  • I looked through internet and noone had same issue as me this might be Hostinger problem
  • I tried to do the same thing locally and it perfectly worked
Note, this is not Hostinger support, just the forum for AMP.
That’s a setting that tends to be controlled by the server.properties file, so you’ll most likely need to change it in the web UI, since AMP flushes the web UI’s settings to the file during every server start.
Also note, that some mods don’t support changing settings while the server is running, so that may be something to check as well.
