| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Sleeping |
Ive downloaded right version of optifine yet it doesnt work only when Im joining the server. It works when I play a single mode. Both the server and I have the lastest version of forge 1.20.1. I would be so so grateful if I could fix this problem. Thank you.
- upgraded both the server and my forge(1.20.1) to latest released version
- allocated more memory usage(heat) of the current server
- deleted configs from old mods that I dont use anymore
- tested if i can run when I play on a single mode with same mods and optifine(and it works)
