| Product | AMP ‘Decadeus’ v2.4.8.0 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Stopped |
I can’t install Forge as a base for the Server. Every time I tell it to install Forge in the Server Settings, it gives me an error talking about a “Missing URL” and says I have to install it Manually.
- I installed a Basic Java 1.20.1 server to start the Instance, and then went to the Server Settings to try and switch it over to Forge.
- I clicked the Drop Down menu and selected ‘Forge’ on the options, and then clicked the Install/Update Button.
- Instead of doing anything, it gives me an error pop-up telling me that the server “Can’t find the URL” and that I should “Try Installing the files Manually.”
