Customization with Minecraft - Cannot Upload worlds
Virtualization QEMU_KVM
When I try to upload my world.zip file it turns into world(1).zip.uploading and then some digits, so I can’t extract it and then when I try to rename it back to .zip it says cannot extract so the tutorials I watched were useless.
    1. Turned the world into a zip file
  • 2.Uploaded the zip file to hostinger
    1. Hostinger turns the zip file to world.zip.uploading and some random digits
  • 4.I rename the file back to .zip
    1. Can not extract that file.
We are not Hostinger, but I would suggest using SFTP for larger files as it’s faster. If you have further issues I would recommend contacting Hostinger support.
Thank you for the response, that really helps XD it worked.
