Customization with Minecraft Bedrock - Bedrock Reimagined doesn't work on my AMP minecraft bedrock server
Product AMP ‘Proteus’ v2.8.0.6 (Mainline)
Virtualization Podman
Application Minecraft Bedrock
Trying to add the Mod Bedrock Reimagined to my AMP minecraft bedrock server and when i load in my grass blocks are purple and black checkers. there are also many many errors about blocks not loading.
  • I have tried reordering my json files with the worlds folder to no avail.
  • I loaded the addon correctly just as i did others that worked properly.
  • i had the same issues with errors trying to use corecraft. odd since corecraft worked fine when i was using pterodactyl panel.
