Customization with Minecraft - Adding a full modpack to Minecraft
I am a slight bit confused as I have set up my own server using personal hardware but never through a hosted server. I am wondering what exactly I need to transfer over and where in order to make “All The Mods 9” Work as intended since there are many more files other than the mods that I don’t want to get damaged or placed in the wrong location. There are also the server files which im not sure I need here or not. I’ve tried to boot it up with the files but after a few attempts I decided to reach out.
  • Installed Curse Forge to the server
  • Downloaded Modpack and accompanying files
  • Added mod files to server
It’s pretty much the exact same. Upload all the files into the main server folder and select the right Forge/NeoForge version that the pack uses.
General import guide here:
https://discourse.cubecoders.com/t/how-to-import-an-existing-minecraft-server-into-amp/1822
Forge FAQ here:
https://discourse.cubecoders.com/t/forge-frequently-asked-questions/2982
So everything is all set up but the server crashes on start with the error being caused by a missing/unreadable .json file for one of the mods. I’ve tried everything I can think off to change that so I am back.
lionfishapi.mixins.json is the file in question
That json file is inside the lionfishapi mod’s Jar.
If their mixins are failing, you’ll want to see if they have a FAQ, or remove the mod
There isn’t much info on it so I deleted it but it still searches for the .json. I looked in the startup scripts where it says to read the json files but it doesn’t have a direct code for that mod, any ideas on how I can force the server to ignore it? Or would possibly starting a new server instance and reloading everything except those mods then trying to launch work?
Exception in thread “main” org.spongepowered.asm.launch.MixinInitialisationError: Error initialising mixin config lionfishapi.mixins.json
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.Config.create(Config.java:153)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.Mixins.createConfiguration(Mixins.java:100)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.Mixins.addConfiguration(Mixins.java:87)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.addConfig(MixinPlatformManager.java:262)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformAgentDefault.prepare(MixinPlatformAgentDefault.java:46)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinContainer.prepare(MixinContainer.java:122)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.createContainerFor(MixinPlatformManager.java:144)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.addContainer(MixinPlatformManager.java:134)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.addNestedContainers(MixinPlatformManager.java:152)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.scanForContainers(MixinPlatformManager.java:213)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.platform.MixinPlatformManager.inject(MixinPlatformManager.java:186)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.MixinBootstrap.inject(MixinBootstrap.java:202)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.MixinLaunchPluginLegacy.initializeLaunch(MixinLaunchPluginLegacy.java:201)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.MixinLaunchPlugin.initializeLaunch(MixinLaunchPlugin.java:34)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.LaunchPluginHandler.lambda$announceLaunch$11(LaunchPluginHandler.java:100)
at java.base/java.util.HashMap.forEach(HashMap.java:1429)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.LaunchPluginHandler.announceLaunch(LaunchPluginHandler.java:100)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:51)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.Launcher.run(Launcher.java:106)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.Launcher.main(Launcher.java:77)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.8/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23)
at cpw.mods.bootstraplauncher@1.1.2/cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141)
Caused by: java.lang.IllegalArgumentException: The specified resource ‘lionfishapi.mixins.json’ was invalid or could not be read
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.MixinConfig.create(MixinConfig.java:1282)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.Config.create(Config.java:148)
… 23 more
That means the mod is still in there, the server gets what JSONs to look for based on the Jar’s metadata.
Be sure that you’ve removed it from both your client and the server.
Then if it still shows up, it means some other mod is embedding it, and you’ll need to figure out what mod is loading it via JiJ (Jar-in-Jar)
