Customization with Minecraft - Accompanying Plugins Do Not Run
Virtualization QEMU_KVM
I’m installing the provided plugins, and they tell me they are installed, but none of them work.
  • Installed plugins from provided menu
  • Rebooted Server
  • Server shows Plugins Installed
Make sure you’re using one of the server types that supports plugins, ie Paper/Spigot/Purpur
It is using curse forge. Is there support for that?
Just to let you know, CurseForge is not Forge, two completely different things there.
And no, Forge/Fabric don’t have native support for plugins, as they’re made for a different modding API.
There are some server softwares that sorta accomplish this, but they’re buggy and introduce a lot of incompatibilities.
Your best bet is to find Forge mods that accomplish the same task.
