Yes, i first tried to update it it normally. I went into the server to test the plugins. And i soon realized that metamod was not loading properly. When i look in the console i can see that the latest metamod build is being downloaded. But it does not launch when i launch the server.
The “Install metamod” and “Install CounterStrikeSharp” Were already turned on when i pressed the update button on the console page.
I forgot to mention that it was working normally before the latest cs2 update. And i have updated before without issues.
Hello hello,
I found this post by chance after encountering the same issue due to the new update.
I’m intrigued by what you said “Leaving it blank will download the latest”.
I’m sorry for being clueless, but could you pls explain what you mean by that? Where do you manually set/leave it blank?
I’m running my own server using Docker, so I’ve been updating Metamod manually myself and it’s quite a hassle.
After brainstorming sessions involving deep analysis and careful consideration, I have concluded that I have absolutely no clue where all of these are.
Evidence hints towards the existence of a certain program or app, which would explain many hypotheses regarding “Miraculous Boxes”. Yet, it remains elusive from my grasp.
