Customization with Application Deployment - Seed
Virtualization QEMU_KVM
hi, i want to importe my own seed for minecraft server, where should i go to enter my seed pls ?
  • Enter the seed
  • enter the seed
  • enter the seed
Manage the Minecraft server, then type “Seed” into AMPs top right search box to find the setting. You can use the search box to find any setting within a given AMP instance.
i try this, the message tell me “Setting Saved” I restart the server and still on the old seed
Restarting the server won’t do anything. The Seed is used to generate the world, its not used beyond that point.
You’ll need to either delete/rename the old world file in File Manager, or change the Level Name setting so you generate a new world with your chosen seed.
Oh yeah thats true, its fine thank you ! :slight_smile:
