Customization with Application Deployment - Plugins will not work
Virtualization QEMU_KVM
I have installed, uninstalled and reinstalled plugins on the Minecraft server but none have worked. What am I missing? Typically I would go in to config files to activate and edit features, but there are no config files I can find.
  • I have installed, uninstalled and reinstalled plugins
  • I have search for config files
  • I have deleted the instance and started over from scratch
You need to use a sever type that allows plugins, like Paper/Spigot.
And there’s some edge cases where some plugins cannot download correctly due to bad developer practices, but that bit is out of AMP’s control.
(usually because the dev directs the download link to a webpage rather than a file, so all AMP can download is a blob of text. which then gets renamed to a Jar)
