| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
I fired up the server as intended. Everything worked. We even did a few days of test building, but when i tried to install the modpacks, they will not unpack correctly. I tried at the end of November to get it to work, but it failed then and i assumed it was an overloaded, or outdated, modkit, so i made a new one, much more cut down, and still nothing works. This is my first time running something like this, so any help is appreciated. Been running this world as a realm for years, and if i can get this to work, we may be doing this business for over a decade into the foreseeable future. Again, your time is much appreciated.
- installed minecraft on server
- installed forge
- tested vanilla server without issues.
- installed modpack as described by the instructions
- tested, modpack failed to work
