Customization with Application Deployment - Mismatched Mod Channel list when trying to connect
Virtualization QEMU_KVM
The modpack I’m using is exactly the same in both my launcher and the server but everytime I try to connect it gives me an error telling me that I have mods the server doesn’t have installed or the versions i have don’t match up. I’ve checked multiple times and it all seems to match up perfectly I’ve even tried testing with all of the client side mods on the server but it gives the same list of mismatched mods.
  • Install mods on server and mod loader
  • Connect to server
  • Get error
what game server are you trying to host and also use sftp to upload
Sorry I’m not super technologically literate so I’m not sure what you mean by using SFTP to upload and the server is for minecraft
let me ask, is this a minecraft mod pack and did you make a minecraft instance first? and sftp is how you upload large files to amp and not though the file manager as that is quite slow and really only meant for like 1 or 2 files
Yes it’s a modpack and I made an instance and set up forge on it before installing the modpack. If uploading using sfpt might fix my issue, is there a short guide you can point me to that’ll help me get that set up?
this can help you out with that. and there is also Forge Frequently Asked Questions about forge faq
