Field | Value |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | QEMU_KVM |
Application | Application Deployment |
Module | ADSModule |
Running in Container | No |
Current State | Indeterminate |
I am trying to export a modpack from Curseforge, and implement it into my server, however it doesn’t seem to be working. I would export the modpack from the curseforge application (The modpack I am working on exporting is called “Cobblemon Beyond the Pixelverse 2” however I somehow found 2 separate tutorials on how to add mods both from Hostinger, one told me to copy and paste the zip folder into the Mods folder, which didn’t work, server ended up displaying that it was missing a chunk of the mods. Another tutorial said to add the zip folder directly into the Root Directory and to extract it in the Directory, which ended with the same effect, and never ended up extracting itself for some reason.
- Export modpack from Curseforge applciation (Cobblemon Beyond the Pixelverse 2)
- Locate and open File Manager within Game Panel
- Download/transfer zip folder into either Mod folder or directly into Root Directory
- Open Server, Server shows missing mods, displays missing mods with 51 extras it cannot show
