Customization with Application Deployment - custom realm not loading
Virtualization QEMU_KVM
join server from minevraft, joins basic bedrock world
  • delete worlds
  • stop server
  • upload zip file to file manager
  • extract here
  • start server
Make sure that the world folder name matches the value you have configured in AMP’s settings
how do I view the values configured in AMP’s settings?
You manage the instance and look under the Configuration tab on the left.
Renaming the world folder to the default world may also work.
Which one do I see it at?
The section titled Minecraft Bedrock
Under the section “level name?”
Yes, the setting should have a description detailing what it does
It still puts in its own random world when I put the file name in “level name”. And doing the .zip just doesn’t load any world.
You’ll have to unzip it for the bedrock server to be able to use it, since zip files are read-only
Yea I did that it isn’t working
Not sure then, I’d suggest googling around
