The node display can be tough when a certain quantity of nodes and servers on that node is reached.
In fact, a way to work around this would be to organize the instances/nodes list ( as an admin ) would be if the nodes are in accordion for example, or another form to sort the node list, or at least make them way all smaller since i may reached a point that i would really have lots of nodes and lots of servers on them.
I can add bootstrap on the AMP.html file’s " " and change the Plugins/ADSModule/WebRoot/Instances.html file to re-organize it to look it.
but as the amp constantly updates that wouldn’t be doable enough I suppose;
Does anyone have any other suggestions for a workaround?
I also plan to manually add a custom on the AMP.html but the file is reset on update.
another possible workaround on this?
