CurseForge ServerType
OS Name/Version: Ubuntu 24.0.4 LTS, ARM
Product Name/Version:
AMP Release “Phobos”
v2.6.4.2, built 10/12/2025 02:30
Problem Description: I Wanna Know if the AMP has native support to Adding modpacks directly from CurseForge.
It will do in a future update as part of the Store plugin. For now though it’s fairly easy to import the modpacks just by uploading them into AMP.
Ok, thanks the store plugin its accessible in some way or not yet?
It’s in the development build of AMP but the curse forge backend isn’t available yet.
Okay, thank you very much, i am loving the panel.
