OS Name/Version: 22.04.2 LTS (GNU/Linux 5.15.0-1037-oracle aarch64)
Product Name/Version: AMP 2.4.5
Problem Description: When I try to install amp I get an error that something went wrong. After trying to run apt update I get “404 Not Found [IP: 198.244.186.210 443]” for “repo.cubecoders.com - /aarch64/ debian/ Release”. I forwarded all ports needed.
Installing AMP...
amp already exists. Skipping...
Updating System...
Installing prerequisites...
Installing Java for Minecraft...
Installing nginx and certbot...
Adding component(s) 'universe' to all repositories.
Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Hit:2 http://eu-frankfurt-1-ad-3.clouds.ports.ubuntu.com/ubuntu-ports jammy InRelease
Hit:3 http://eu-frankfurt-1-ad-3.clouds.ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Hit:4 http://eu-frankfurt-1-ad-3.clouds.ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Ign:5 https://repo.cubecoders.com/aarch64 debian/ InRelease
Err:6 https://repo.cubecoders.com/aarch64 debian/ Release
Hit:7 https://packages.adoptium.net/artifactory/deb jammy InRelease
Reading package lists... Done
E: The repository 'https://repo.cubecoders.com/aarch64 debian/ Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Checking settings... Domain host.jjscore.games resolves correctly to 158.101.172.104.
Adding CubeCoders DEB repository...
Installing instance manager...
- Installing via package manager...
Failed to install instance manager. Aborting...
Possible causes for this are an unsupported distribution, or the repository being in the middle of a sync. In which case wait 30 minutes and try again, re-running the same installation command.
Something went wrong during the installation. Would you like to upload your setup log for easy sharing?
This will upload /root/getamp-20230620-105217.log to the hastebin service and give you a URL you can share.
The log file may contain sensitive information such as username, any supplied domain names or your systems hostname
so if in doubt - check the file manually and upload it yourself.
[y/N]
Also here I’m running apt update
Hit:1 http://eu-frankfurt-1-ad-3.clouds.ports.ubuntu.com/ubuntu-ports jammy InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Steps to reproduce: Installing amp
Actions taken to resolve so far: Tried to remove the repo and run installer again. Also rebooted the server.
