OS Name/Version: Ubuntu 20.04
AMP Release “Triton”
v2.3.3.4, built 06/06/2022 18:55
Problem Description: Hi, i have a problem with my CSGO server im new to AMP recently bought a license i have installed AMp and all is good i suppose but when i create a CSGo server i get this when i press on it ;
Binding | 127.0.0.1:8081 |
Endpoint | 0.0.0.0:27015 |
also it shows in the instance as this Screenshot - f92bebb4d67908a0d30d69b4f950c585 - Gyazo the ip/port 0.0.0.0:27015 ,
also when i try to change a map in source server settings to be as start map from de_dust2 to a Zombie Escape map i try to join and server crashes ive upluaded the maps correctly i dont know what the problem could be ?
provides syntax highlighting.
Actions taken to resolve so far: changed this : “Server IP Address
Which IP address the SRCDS server should listen on.”
