OS Name/Version: windows 11
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.4.0.8
Problem Description: i am ran into crashing issues every time i do remote instance it giving error some odd reason once ads shutdown i cannot reset the ads until i reboot doing that every time i modify other instances not local
- upgrade to 2.4.0.8
- login any remote instance using local ads
- then when resetting ads port in used
- reboot, then repeat
Actions taken to resolve so far: only reboot, but unable to solve this
update
another crash wo me login
from remote
[22:53:41] [GSMyAdmin:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[22:53:42] [GSMyAdmin:Anonymous Error] : HttpRequestException
[22:53:42] [GSMyAdmin:Anonymous Error] : [0] (HttpRequestException) : An error occurred while sending the request.
[22:53:42] [GSMyAdmin:Anonymous Error] : at AMPAPI.RemoteInstance.<GetResponseDynamic>()
at AMPAPI.RemoteInstance.API_Core.<Login>()
at GSMyAdmin.Authentication.RemoteAMPAuth.<Authenticate>()
[22:53:42] [GSMyAdmin:Anonymous Error] : WebException
[22:53:42] [GSMyAdmin:Anonymous Error] : [1] (WebException) : Unable to connect to the remote server
[22:53:42] [GSMyAdmin:Anonymous Error] : at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
[22:53:42] [GSMyAdmin:Anonymous Error] : SocketException
[22:53:42] [GSMyAdmin:Anonymous Error] : [2] (SocketException) : No connection could be made because the target machine actively refused it 192.168.2.86:8080
[22:53:42] [GSMyAdmin:Anonymous Error] : at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
[22:54:13] [GSMyAdmin:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[22:54:14] [GSMyAdmin:Anonymous Activity] : Authentication success
[22:56:14] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[22:56:15] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication success
[22:57:14] [GSMyAdmin:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[22:57:14] [GSMyAdmin:Anonymous Activity] : Authentication success
[23:00:14] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[23:00:15] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication success
[23:01:14] [GSMyAdmin:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[23:01:14] [GSMyAdmin:Anonymous Activity] : Authentication success
[23:04:14] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[23:04:15] [GSMyAdmin:AMP_SYSTEM Activity] : Authentication success
[23:11:42] [GSMyAdmin:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.0.35
[23:11:47] [GSMyAdmin:Anonymous Error] : TaskCanceledException
[23:11:47] [GSMyAdmin:Anonymous Error] : [0] (TaskCanceledException) : A task was canceled.
[23:11:47] [GSMyAdmin:Anonymous Error] : at AMPAPI.RemoteInstance.<GetResponseDynamic>()
ok i have fixed the bind issues on 0.0.0.0 to ip after each crash no longer kill on port using, now crash on latest error shown above
soo 0.0.0.0 is known issues for port issues
change 127.0.0.1 or lan ip as default not 0.0.0.0 on windows only
not sure of Linux not tested
[04:28:03] [GSMyAdmin Error] : [Error] --- Begin Exception Data ---
[Error] OS: Windows (x86_64/None)
[Error] Module: ADSModule, Version: AMPService 2.4.0.8
[Error] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
[Error] Instance ID: 9fa4ad3b-ecca-46cc-967d-8033ea043070
[Error] InvalidOperationException
[Error] [0] (InvalidOperationException) : The WebSocket has already been started.
[Error] at Net.WebSockets.ClientWebSocketOptions.ThrowIfReadOnly()
at ADSModule.RemoteTasksMonitor.<Connect>()
[04:28:03] [GSMyAdmin Info] : Uploading error report...
[04:28:03] [GSMyAdmin Info] : Done!
[04:28:03] [GSMyAdmin Info] : ####################################
[04:28:03] [GSMyAdmin Info] : # Self Diagnostics #
[04:28:03] [GSMyAdmin Info] : AMP Diagnostics could not establish a solution for this exception.
