Convert to Controller and Target
OS Name/Version: Windows 10
Product Name/Version: AMP 2.5.1.8
I have setup a standalone PC server. However, I would like to change to use multiple PCs for more server capacity. I thought I could probably just uninstall AMP and re-install it selecting the controller/target on the new install. However, I never even got he option to select the type after the new install. It looks like uninstalling also does not delete your old instance info, as I could see the old server instances immediately on the new install. What am I missing to try and setup the target controller setup. Perhaps my search technique sucks, but I could really find no info on doing this.
uninstall and reinstall
Tried uninstalling and re-installing
You can just re-run the setup in the ADS’ settings
