Controller And Target Setup
OS Name/Version:
Windows 11/23H2 on both target/controller
Product Name/Version:AMP/Phobos mainline with the patch from 01/24/25 on both. I’m sorry I cannot see it on the installer currently on the target.
Problem Description:I have never setup an amp installation with controller and target. I have installed amp in controller mode on the controller pc with its own login info.
The target pc has started installation,but not finished, it has a separate login info. but when I come to the page asking for the ads controller url and login info I do not know what to do. I tried using the local ip address of the controller with port 8080 and the login details of the controller but it did not work. I’m sorry if I don’t make any sense but I do not know what ads controller url means or what it is. I do not know if the controller/target need to have the same login info. Basically how to setup controller/target on 2 computers, same network.
With the controller URL it needs to be the whole URL.
Eg: http://the.controllers.local.ip:8080
(it doesn’t automatically add the http because it supports both http and https)
I was not expecting a reply that fast, I will try that now.edited- that worked like a charm. I appreciate your help. It’s the simple things that will drive you mad. Thank you very much lol
