Console showing limited output - Minecraft Fabric
OS Name/Version: Ubuntu Linux 24.04.2
Product Name/Version: Professional Edition - 2.6.1.6 - 20250421.1
When I open the console window for Minecraft Server with Fabric installed as the server.jar (Haven’t tested with other servers) it seems the console is limited to 40 lines. When I i.e. type /help it only displays the last 40 lines of options available.
  • Start instance
  • Go to console
  • Type in console /help
I have tried to untick “Supress garbage output” Under Configuration > Minecraft > Server & Startup but without luck. I don’t see anyone else writing about it, and can’t seem to find any setting to “unsupress” the console view. Any ideas or help is appreciated.
Known visual issue in AMP’s console implementation, currently being looked into afaik.
You can read the logs/latest.log to see the full output.
